Click HERE to order or for more information.
VW MK7 Steel Oil Pan Replacement -
Your factory oil pan has some major design flaws due to being made of plastic. Depending on the severity of an impact, your stock pan is prone to cracking and leaking oil. Furthermore, when changing your oil, the risk of over tightening and stripping your plastic threads poses yet another risk.
Relieve the worry of an unfortunate impact creating an oil leak from the factory plastic oil pan or stripping your plastic threads by replacing it with a superior stamped steel alternative.
